Leaking injector AGAIN!
RE: Leaking injector AGAIN!
Just use dielectric grease or a sillicone based lubricant to lubricate the injector o-rings. From personal experience if you had a leaking bottom o-ring (where the injector goes into the intake) you more than likley have a vacuum leak. I would be more suspiciuos (however you spell that word) of the injector itself or the upper o-ring.
is your fuel rail tight i put mine in one time and the bolt wasnt all the way tight in the back and the rail lifted up a little so i pushed it down and tighted the bolt and it was good after that
Gas was just laying on the intake right under one injector so i figured it was the o rings so i replaced them and cleaned off the engine. Now the same exact thing is happening again and it is not in the same spot. I did not put the injectors back in their same spots when i did the o rings. Thats how i know that it is not the rail. I am asking you guys because i dont want to buy a new injector if i dont have to and i dont want to keep having to remove the intake. Thanks for the help.
