saleen heads help
RE: saleen heads help
^^+1, but check casting numbers on the heads. Not sure that saleen made their own heads for 5.0's 93's, but i could be wrong. Google 93 saleen and see if you can find out what kinds of goodies got thrown in the mix so you don't get ripped off.
looks like the saleens after 89 went up to around 300 HP which means that most likely changed the heads/cam and other stuff. Make sure you check the heads out before you buy, cuz i can't see someone stripping a saleen apart unless it's been wrecked, and then still i would try to keep the engine intact since the saleens are kinda rare. Good luck!
