plans for my car- your input...
Here we go: my current mods are:
3.90 gears
3000 rpm converter
shift kit
trans. cooler/gauge
ported lower intake
u/d pulleys
shorty headers, x-pipe, dynomax ultraflow with dumps
subframes, control arms, front lowering springs
electric fan/no smog pump.
all that is good for an 8.8 at 79 mph with a 2.0 60ft.
My plan this summer is to:
convert to t-5 and sell the converter and aod to make some money back.
convert to manual rack to get rid of that whining power steering/stealing pump.
buy a used nitrous kit with a 190 lph fuel pump.
with these mods i'm hoping to run 8.4's n/a and 7.8's with the juice.
any input, question, comments?
3.90 gears
3000 rpm converter
shift kit
trans. cooler/gauge
ported lower intake
u/d pulleys
RE: plans for my car- your input...
ORIGINAL: ROTTITANK
heads AFR
heads AFR
i was thinking about that, but than i would still be stuck with an auto that is starting to slip from 2-3 and 3-4...
you you want to get faster than invest in some supspension mods..keep the automatic..also converting to a manual rack will get some wt off the front with deleting the ps pump...you can use 1 from a ford fairmont and I believe autozone has them for about 100.00...those lowering spring in the front doesn't help wt transfer unless, they are from a 4 banger or a drag spring
I would invest in some 1.7 rocker to help the stock cam, I hope you have a bigger maf like about a 76mm C/L
2 kwik- i meant to say an upgraded maf sensor will be bought sometime next month.
rsw007- i know you have had great success with your combo, but i would be spending a ton of money (around 1500-2000?) on essentially the same thing...
My budget is about 1500 dollars:
T-5 swap ~600 dollars if i sell off the old parts
MAF sensor with intake tube~200 dollars
Used nitrous kit~350
manual rack~150
watcha think?
manual rack~150
watcha think?
