87-93 heads on a 86gt?
#21
RE: 87-93 heads on a 86gt?
I am positive they won't work. I've tried on a t-bird 5.0 engine changing it to an H.O. You have to notch or replace the pistons.
Also just because they have a "6 second mustang" doesn't mean they know squat about the 302's, if they have a 6 second car it's not with THE (as in ford 302) 302, or any ford motor for that matter. And they don't have a 6 second car I can 100% guerantee that, assuming it's a pro-stock car, because I know the guy who held the record for awhile in that class, ran something like 8.2x or something, he owns a performance shop here, my dad used to be in buisness with him.
#22
ORIGINAL: Liquid_02
With E7's it's not a 12 second car, I doubt you'll gain any time, maybe a tenth. Can only do so much with factory heads
ORIGINAL: pitman86gt
i see u have a 86. are u running stock heads or what is ur setup. hey u know what is funny. this car ran 13.5's with the valves touching the pistons. imagine if i had clearance and with all the new stuff done to it. should be a 12 sec car with straight valves.
ORIGINAL: Twister
Chevy is 1.5, Ford is 1.6
#23
i am telling u they work. i had them on. been on there since 98
with 1.7's. i think it is motor to motor from what mechanic told me. not all engines and heads are the same deck height. and i dont know if i said it before, but the pistons are cut do to the old valves hitting the piston.
#24
#25
ORIGINAL: Liquid_02
It's not motor to motor :\ if it was motor to motor the difference would be so slight it would be un-noticeable, like 0.001" - 0.005" ish, it's not motor to motor. I wouldn't take it back to that mechanic, because I can tell you right now he's a dumbass if he thinks the valves notched it themselves. The valves are bent right, so they may be "notched" where your valves were bent to, now, when you you straight valves in there they're going to be longer, right? And the "notched" area is now not where the new valves sit. So your pistons are going to slam right back into them and you're going to have to go through all this all over again. Besides, the burr on the pistons are going to creat a hot-spot, and you're going to burn it out.
#26
I don't know the thickness of the top, but you know what? What do you honestly have to lose? Grind them down as far as necessary and see if you can make clearance, if you go through, you need pistons, not the end of the world. If you dont at least try, you'll need e6 heads. There should be plenty to notch them though, I had plenty.
#27
ok thx bro and no hard feelings about the piston notching and ****. i just want to figure it out. but i know that 1.6's will give me some more room. also if u know anyone wanting to trade 1.6's for 1.7 crane cam roller rockers let me know. they are pedastal mount. and do u have a 86 with flat tops
