Question about alternator/ac swap.
Ok the title is probably pretty confusing but I'm looking to delete my a/c system (hasn't worked for like 1 and a half) and I have seen some pics of peoples cars that have the alternator where the a/c compressor was, in order to keep the belt routed the correct way. I currently have the smog off and the p/s off and the a/c is the next to go. I know that UPR sells an idler pulley but I kinda wanna make my car have the least amount of pullies as I can. Does anyone know a company that makes a kit or bracket or anything that will allow me to put the alt over on the a/c space? Any help would be appreciated. Thanx.
RE: Question about alternator/ac swap.
i know what you're talking about, but i dont know who makes it. you could always put on an electric fan, leave the alternator where its at, and run it off the crank with a small belt routed around the water pump and crank
im just going to delete my ac and run the belt straight under it, since itll run like that too. thats how it runs on the mustangs without ac's. only question i have is how much hp will i gain from deleting the ac?
ORIGINAL: Ecstasy
i was told itll give me 5-10 maybe a little more hp.
not when the a/c isn't on.
with the a/c is off the belt is basically running over a well-bearinged idler pulley.
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
