Crossover tube between heads?
RE: Crossover tube between heads?
ORIGINAL: Twisted
Still trying to troubleshoot code 94. Has anyone heard of the crossover tube for the thermactor system becoming clogged? Also, how hard is it to remove this tube.
Thanks for the replies folks. So is it easy to get the pipe off of the heads? It looks like it might be tough. Also, will I be able to clean the passages in the heads w/the heads still on the car?
ORIGINAL: 5.0stanger
Carbon from the exhaust. You are probably burning some oil.
Not that hard to remove....a little uncomfortable at the back of the heads, but that's it.....just make sure you work on a cold engine though. GL
Added: A word of caution, careful how you handle the check valves, if they're a little old they tend to snap in two.
