Suggestion on Valve Covers
RE: Suggestion on Valve Covers
ORIGINAL: r.barn
+1, or make sure you use a high temp paint made for engine blocks.
ORIGINAL: 5.0stanger
Get them powder coated.
I always liked the squared off fabricated aluminum ones, or the black powdercoated cobra's but for the money and considering with an EFI manifold most of the cover is blocked from veiw anyways I just sanded and painted mine silver for now.
im gonna get these http://mustangsunlimited.com/itemdy0...s&CatKey=74-01
ORIGINAL: grabbem88
this is what i use...some aftermarket 1.6's won't clear stock v/c's...
no you must remove the upper intake. you can get the passenger side by removing the TB but you might as wells keep it on the intake, the intake has 6 bolts that are easy to do, just remember the two under the plenum cover
