WHAT NOW? CAR WONT START. READ THIS! GRRRRRRRR!
RE: WHAT NOW? CAR WONT START. READ THIS! GRRRRRRRRRRRRRRRRRRRRRRRRRRRR
Stick a new battery in to see what happens. If it will start and run off a new battery, then you next disconnect the battery to see if it continues to run off the alternator. Maybe the alternator is dead and not charging the batt, and for some reason that batt isn't taking a charge now. When the car is off, do the lights light up bright and all, or are they really dim like the battery is dead? What voltage do you get from the battery itself, and does the whole problem go away when you disconnect the foglight wiring?
ORIGINAL: grabbem88
bat is drained....start it next time and unhook bat. if it dies then you'll know it's alt.
it's not when you don't have the tools..
and joel FYI if his electrical is that far jacked on bat drain...it won't hurt...i know guy's that race with no alt.
just bat...
just bat...
ORIGINAL: grabbem88
just bat...
just bat...
actually iv'e seen both ways....i know your not mad at my comment,remember we have newbs that are learning so i should of told him"you can do it this way,but don't it unless you have to....here's the right way"...
hold up that's why i have you cleaning my mess up...
ORIGINAL: grabbem88
RE: WHAT NOW? CAR WONT START. READ THIS! GRRRRRRRR!
OK,
Here is where I am now.
I took the battery to have it tested. The battery charged and tested fine!
I took the alternator off. Took it to Advance to have them test it. The amperage was good. But in a KEY NOTE it said that light on wiring should be off! Well it was lit up red??? So they told me the alternator was bad??
I took the alternator to auto zone and they checked it and said it passed all tests? THey didnt have the little light wiring on their testor, a completely different tester.
SO, I come home and do a light test on the neg post and neg cable. THe light comes on. I went through every fuse removing them one at a time. The light testor came on with every fuse removed one at a time?
Now what the hell is going on?
I have my multimeter out. I left the pos battery cable hooked up. I undid the negative. I put the black multimeter wire in the COM CAT II hole, I put the red wired in the 10ADC hole. I turned the **** on the meter to 10A (in red). I touched the wires to the neg cable and the neg battery post. I cant get a read. What am I doing wrong here? Any more thoughts? Thanks.
buy a new alternator. it sounds like its not charging to me. I replaced mine even though it passed the test at the auto parts store. I took it to two different ones like you did, one with the light and one without, and had the same results. I just replaced it and the battery, cause they battery was old anyways. it works great now
