WHAT NOW? CAR WONT START. READ THIS! GRRRRRRRR!
#22
RE: WHAT NOW? CAR WONT START. READ THIS! GRRRRRRRR!
I guess I need to see how large of draw I have.
Can someone tell me exactly how to do this with my scosche multimeter. I have never used one. In my above message click the link I have for scosche meter and then click on the picture to enlarge it. Can you tell me the settings I have the ****, where I plug the red and black wires. Also, how to have the battery and cables. Let me know asap so i can go check. Thanks, Landon.
#23
ORIGINAL: biglg
Now what the hell is going on?
I have my multimeter out. I left the pos battery cable hooked up. I undid the negative. I put the black multimeter wire in the COM CAT II hole, I put the red wired in the 10ADC hole. I turned the **** on the meter to 10A (in red). I touched the wires to the neg cable and the neg battery post. I cant get a read. What am I doing wrong here? Any more thoughts? Thanks.
Suggestion....start by checking the main fuse links at the starter solenoid, and isolate which one is causing the drain, by connecting one at a time to the solenoid, and monitor the test light...then check which color the wire(s) is/are and use this power dist. diagram(Courtesy of TMoss and Veryuseful.com) to id the culprit circuit possibilities.
#24
OK. I think this is now over my head. LOL. The test light I have has a black lead, and the positive is the metal tip. It lights up red or green.
I dont know what you mean by the test light to bright? I am confused. To my knowledge it lights up, or it doesnt?
#26
your test light may not be the best tool for this, because any voltage is going to illuminate it. you might want to try a bigger light, like a headlight. and those fuses in your DVOM can be a bitch to change [:@]
#27
My bad then....thought you were using a regular 12vdc test light......which is the equivalent as using an 1156 replacement bulb....and should give you an idea how strong/faint the drain is (NPI)....
#28
Well can either of you tell me how to use the darn multimeter on the negative terminal and negative cable?
I put the black wire in the COM port, the red in the 10adc???? What do I turn the **** too? This is the multi meter I have. multimeter Click the picture to enlarge to tell me exactly where to set it. Thanks.
#30
So the black wire in the com, the red wire in the 10adc, and the center **** to the 10A? Then take the red wire and the black wire to the negative post, and negative cable with the cable disconnected? Leave the postive cable on?
Do i turn the meter on the touch the post and cable? I did this earlier at these settings and go 0 on the screen?
