Not with the pressure it just feeds the supply the motor needs, there is no exact fuel pressure limit when you start modding your engine, you have to play around a bit check your plugs and even get a Air Fuel ratio gauge to pin it down, the 38 is stock with 19 lb injectors you have 30's and if you run 38 with 30 # ers you are going to be flooding the engine unless you have some nice engine mods.
