front bushings!!!
front bushings!!!
What do front bushings in the lower control arm look like when they are worn. I jacked up the car and the bushings look all torn and smashed up. would that cause a thunking noise when going over speed bump or when steering wheel is turned sharp left or right?
RE: front bushings!!!
i am doing caster camber plates, 8 position adjustible gas shocks, all 4 tie rod ends, both ball joints and all polyurithane bushings in my 94 gt, also drilled slotted rotors and new ceramic pads. anyone have any tips? im figuring itll take me 5-6 hours per side.. is that ball park? what tools will i need other than the ball joint press? any help is appreciated!
