Mass air conversion = no start
did the swap tonight and the fuel pump isnt priming.....could anyone tell me what these plugs are for? the first one wasnt on the original harness
http://i5.photobucket.com/albums/y17...30240/plug.jpg http://i5.photobucket.com/albums/y17...0240/plug3.jpg http://i5.photobucket.com/albums/y17...0240/plug1.jpg |
RE: Mass air conversion = no start
and i didnt splice the original harness, i bought one off of a mass air car
tell me where they are and I'll go take a snap of them, my car's all apart and running
2nd one i know where it is and it's not connected on my car either, think it's for the charcoal canister but I don't know, I got rid of that. |
first one is next to the connector for the computer, second is next to the relay on the inner pasenger fender, and the third is by the computer
i also cut the fusible link behind the battery out
Ok, I don't have 2 or 3 connected, I don't even see a connector like your first, and your third I have the male fitting for aha, no female. and the middle one might be for your TPS, or for nothing like I have it as.
first one was a few inches from the computer connecter, and the last is next to the relay on the inner fender
ORIGINAL: primetime5.0 first one was a few inches from the computer connecter, and the last is next to the relay on the inner fender Is the first one in the driver side quarter panel? because that's for airbags if it is, looks like an airbag connector. Im so lost, could you get a picture from a little farther away? so I can see where I should be looking? |
the first and last one are inside the kick panel. the second is next to the alternator on the inner fender
Ok Here you go. 8 pin connector, comes from dash harness, runs down just before the door jam as seen in picture below, as does the small 2 pin connector (which I don't have the the female one for so it's not connected, cant do much)
(See the harness that runs up the to the dash on the right, that's where they come from) https://mustangforums.com/upfiles/16...EF57AC6408.jpg https://mustangforums.com/upfiles/16...00FF46590C.jpg |
