how the hell do you pass smog when you take out the smog pump? You need serious connections, don't you? Especially in the ****-state (California, my home).
you dont need a delete kit. take off the pump. use 3/4" vacuum caps to plug the h pipe and the fitting that goes to the heads. buy a 84.5" belt. your done.
what size belt would you need if you removed the smog pump, removed the ac and moved the powersteering up to the spot the ac was in? i have the ford kit coming in the mail right now.
my car didnt come with an h pipe..do u know where else it might be? it only has the one in the heads wich is already plugged.
