blinkers on the blink - MustangForums.com
Old 05-03-2006, 09:50 PM
vudu
Default blinkers on the blink
today went to use the blinker and nothing. other direction, again nothing. try hazzards and they work. i have no owners manuel to show me what fuse to check. also,noticed at the same time that the air bag light is staying on. any guesses? any info would be appreciated.
vudu is offline
Old 05-03-2006, 11:43 PM
Twister
Default RE: blinkers on the blink
it is one of the 2 flashers under your dash, it is not a fuse....the lights just stay lit, correct?
Twister is offline
Old 05-03-2006, 11:57 PM
vudu
turning on the blinkers, nothing happens. no light in the arrows in the instrument panel, no blinking sounds, nothing.
vudu is offline
Old 05-04-2006, 12:06 AM
COMPMACH
Spray some eletric spray or wd40 down inside the hazzard button and work the button several times,the blinkers should come back.
COMPMACH is offline
Old 05-04-2006, 12:51 AM
5.0 MPG
there should be a relay for both your hazards and blinker. Find both and interchange them. If your hazards come on after that then its your switch, if not you need a new relay or to just clean them with electrical cleaner. By the way the electrical cleaner is great stuff. I use it for degreasing works better than the other stuff.
5.0 MPG is offline
Old 05-04-2006, 12:53 AM
vudu
thanks
vudu is offline
Old 05-04-2006, 12:59 AM
Twister
if there is no light, it is not the flashers, it is either the fuse or the switch
Twister is offline
Old 05-04-2006, 01:08 AM
vudu
thanks
vudu is offline
Beerman309
09-19-2015 02:16 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 10:43 AM
amandahchase
09-03-2015 11:09 AM
GNut_96GT
08-06-2005 06:38 PM
schardt_greg
04-15-2004 12:09 PM
Quick Reply: blinkers on the blink
Featured Sponsors
© 2018 MH Sub I, LLC dba Internet Brands
