hard to climb past 85ish MPH
Ok heres thedeal on this problom... when i take off in 1st gear it some times doggs out and than climbs fast at the top of my gear, like at 2,300rpms to 5000rpms. and it dogs out at the bottom of all my gears whats the deal on the sitituition? another thing when i am going like 85 and shift in to 5th it wont climb like at all, well verry verrrry slowly. I have only got the car to 115 and than let out. And after dong that and slowing down to get off on my work exit, i can smell a kinda weird smell. but the cars not over heating... and one mre thing theres a weird smell as i am taking left hand corners at like 65? smells kinda like burnt rubber. but noit i dont think...PLease help me out!!! thanks and have a good night...
Aaron Dean.
Aaron Dean.
RE: hard to climb past 85ish MPH
ey i have a 94 mustang and in my car i couldnt go passed 3500 rpm i had to shift at or before 3500 even if i would keep on flooring it it just woulnt go any were every single gear was like that, and it was wasting to much gas, and all that was rong with it was a spout connector, i dont know if this is related at all to your problem but just tought it might help, my spout connector was only $10
5th gear is an overdrive gear and it' not designed to pull, just let the engine slow down some and then you can get a higher top speed overall, but it takes a while to get there in overdrive. without the OD, you wouldn't have gotten to 115 at all. don't know what the smell could be. as for the smell when cornering, it could be burnt rubber as you don't have to spin the tire to burn the rubber but spinning sure helps burn it quicker.
Yeah the cats are still on the car for now, can someone tell me where to get some straight pipes or some type of pipe to weld on to bypass the cats? will it make my car faster? And the smell might be the overflow from the raditor cause theres not a overflow tank... But the caps holding alot of pressure we tested it...
sounds to me like you could have a MAF sensor problem. My MAF was bad and the gears would be sluggish down low, then when in fifth gear it would barely go anywhere. Simply because the malfunction in the MAF was messing with the MAP and not reading the air correctly, causing it to not perform correctly. Check that out, hope it helps.
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
