racing last night fueled my fire.
after racing at the gainesville raceway last night, i am excited about being able to get some traction. not sure what order to do it in. thinking this order, 1) subframe connectors. 2) m/t drag radials. 3) shocks, struts & springs. 4) u/l control arms.
i am unsure of what springs to get, want to lower it down some 1-1 1/2" . what would be best, drag launch springs or just lowering springs? will i need a pinion snubber and c/c plates and bump steer if i lower it ? thanks.
RE: racing last night fueled my fire.
Start with the subs first you don't want to twist up the body a lot. the order you have it is the way I would do it.I would get adj. struts and shocks. Also lowering the car in most cases hamper the way the car leaves so I would not lower it but that's just me.
My car is pretty much bone stock but launching it on slicks to many times twisted the chassis enough to crack it at the floor pan and up the trans tunnel. I would recommend full length subrames, with large diameter tubing, not the 1"x1.25" inch most companies sell. I would definitly strengthen the chassis before getting traction.
...about your suspension.
Is your car a daily? What are your plans? If it is a track only car, then drag suspension hands down. If it is a daily, drag suspension will drive like donkey sex for everyday use.
TfcCDR
09-14-2015 12:08 PM
09-09-2015 10:30 AM
mungodrums
Suspension
09-07-2015 07:28 PM
