EFI??
RE: EFI??
more technical knowledge than you have if your asking what itll take...
however ill take a stab at answering it for you!
You will need:
Upper and lower intake manifold
new fuel lines
new fuel pump (in tank)
8 injectors
fuel rail
a bunch of wiring
a EFI computer
MAF
TB
IAC, TPS etc etc
basically alot of stuff and youll be unhappy with the amount of money youll have to put into it to get it going.
check out some of the aftermarket EFI tuning forums and sites like:
www.diyautotune.com
www.sdsefi.com
www.haltech.com.au
www.megasquirt.info
You will need:
new fuel lines
8 injectors
fuel rail
a bunch of wiring
a EFI computer
MAF
TB
IAC, TPS etc etc
www.diyautotune.com
www.sdsefi.com
www.haltech.com.au
www.megasquirt.info
RE: EFI??
well it wont need E test, wel i duno about where you are but in canada if its 20 years old you dont need it. it will certify no problem if you do everything properly. i cudnt get mine cert bc my front bumper and **** is cracked. a few small things. i got one though.
if you do it take ur time. id say get a parts car. you need to get a tank from a fuel injected car. run all the wires, put in the F/P relay under the drivers seat. I changed my dash to an 88 because i dont think the computer will come on if you dont. computer goes into pass. side kick panel, there is a hole in the firewall for the harness. lots of work, I honestly wouldnt do it unless you have a parts car.
hope that helps if you have questions ask me.
RE: EFI??
Not to jack this thread or anything.... but you two Massachusetts guys should check out
www.neboc.org
there is a meet coming up on the 21st at the picadiliy pub in tewkbury. we just had a meet down here in RI at the A&W drive in diner.
beginning of next month we have a cruise to cape cod
www.neboc.org
jaiidutch
09-14-2015 10:29 AM
YoungStangsMan
09-05-2015 07:01 PM
