mass air flow
whats the best brand maf out there and where can i find it at, having trouble finding one for a 94 gt
RE: mass air flow
i got C&L from brothers mustang
RE: mass air flow
C&L or PMAS (was Pro-M) are the best out there. Vortech is the same as C&L and Granetelli is the same as Pro-M....... C&L's have sample tubes you can buy for $30 when you change injectors instead of having the electronics recalibrated like PMAS.
I went w/ PMAS 75mm though.... |
RE: mass air flow
you can use a used one as they don't wear out try e-bay or here
www.corral.com |
RE: mass air flow
what you mean by recalibrating it when you replace it?
RE: mass air flow
i have a 94 gt and i have a granatelli mass air in it.. got it from summit tuned for 30# 's and cold air tune.. plus its chrome $259.99
RE: mass air flow
it has to be the right one for the injectors you use. different ones are set to work with different injectors. so if you have 24's, get one calibrated to work with 24's
RE: mass air flow
cant i just buy a 75 maf and slap it on to a stock engine?
RE: mass air flow
dang right you can. stock has 19lb injectors so you need the one calibrated for 19's. the add will say which is which.
ORIGINAL: Mustangkiler cant i just buy a 75 maf and slap it on to a stock engine? |
RE: mass air flow
Pro-m all the way
