UNREAL
UNREAL
well i am about two hours away from having my car done(mods listed) after 6 months, and im putting on my valve cover and the fuggin bolt breaks off in the head---i about crapped my pants.....am i screwed or can it be fixed? anyone ever have this happen?
RE: UNREAL
ORIGINAL: gt884me
Nah its actually a little in the head
RE: UNREAL
if its a clean break take a hole punch and make a nice dent in the center of the stud. Then take a real thin bit and drill a hole about a quarter of an inch down. The take a reverse screw and thighten down until it comes out.
Or walk the screw with the hole punch. You need to make a dent on one of the sides of the screw and slant the punch then use the hammer to unwind the screw. Its tedious but once you get it outside the lip your home free.
RE: UNREAL
For that size "sears" also makes a "remover" You still need to center punch it to get the bit started but it is a screw remover set that you use in a drill. I have had good luck with it for small, low-torque situations. Other than that those things previously posted should also work.
