combo confusion?!?
combo confusion?!?
so i just got done putting together my little combo and was curious what u guys thought about it (ex: power, somthing doesn't quite match with others..) i haven't put it in the car yet and just wanted to know what you guys tought. here's what i have; 306 w/ an F303 cam (.512" & .512"), 1.6 roller rockers, Trick Flow Track Heat intake, ported stock heads, 24 lb injectors, 255 lph fuel pump, 75mm throttle body (overkill?), 77mm MAF, 1 5/8" primary to a 2 1/2" coll. long tubes, matching pro chamber followed by a set of 40 series, under drives, a/c eliminator, smog delete, E-fan, all in front of a rebuilt AOD w/ a shift kit and a 2300-2500 stall and a set of 3.73's. what kinda realistic times do you think i could expect?
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
mrappe
09-26-2015 10:16 AM
