What's your mpg?
RE: What's your mpg?
I just refuled yesterday at 237 miles to the tank, and I was not even in the red .. I had a feeling the needle was going to drop though, still have not totally figured out the temperment of the gauge yet. Those are all city miles ..with a few uses of the AC as well... I have not had it on the freeway yet. I have only had it for 2 months..
95 GT Vert. all stock except possibly a catback..
i get about 12mpg but i never ever drive on the freeway. thats street driving
MODS ARE:
K&N air filter
Pro-m 80mm MAF sensor
Professional Products 70mm throutle body
Professional Products 70mm EGR spacer
Professional Products intake manifold (upper and lower)
Mac equal length shorty headers
Summit Racing catless H-pipe
Flowmaster-Delta Flow mufflers (with dumps)
NGK spark plugs
Mr. Gasket high flow 180 degree thermostat
electric radiator fan
MSD 8.5mm super conductor spark plug wires
MSD TFI ignition coil
MSD 6AL ignion box
Powerslot slotted rotors
Hawk Racing performance pads
Edge Racing 3200rpm stall torque converter
B&M transmission cooler
AFR 165 aluminum heads (58cc)
Scorpion aluminum roller rockers
hardened push rods
Trickflow 3/8" heat spacer
Strange 10 way adjustable rear shocks
UMI rear upper control arms
Mega Bite Jr rear lower control arms
adjustable pinion snubber
weld in sub-frame connectors with seat support
4 cylinder mustang front springs
strange 10 way adjustable front struts
Ford Racing 3.73:1 gears
Ford Racing 31 spline limited slip differencial
Moser 31 spline hardened axels
Torque link
adjustable fuel pressure regulator and gauge
T-rex inline fuel pump
Ford Racing 42# injectors
255lph in tank fuel pump
battery relocated to trunk
Load Boss 3G 150A alternator
Vortech S-trim supercharger (3.00" pulley)
AFM methanol/distilled water injection
UPR boostmaster pipe
programmable engine management system (PMS)
think thats all of it
MODS ARE:
K&N air filter
NGK spark plugs
MSD 6AL ignion box
hardened push rods
Torque link
