I need some info!!
Old 05-10-2006, 02:07 AM
BurninOne
BurninOne's Avatar
Default I need some info!!
I have a 94 GT and I was wanting to know is there anything I could do to up my power some and not hurt my mpg, I aint lookin for a drag car I just want more than stock. is there any lil things I can do to give it some more pickup and go and still have it has a everyday car and long trips
BurninOne is offline
Old 05-10-2006, 02:11 AM
gspfunk
gspfunk's Avatar
Default RE: I need some info!!
1--Gears....they may hurt your mileage a little, but the performance trade off is well worth it....if you're really worried about gas, go w/ 3.55's...I like mine
2--remove your air silencer in the passenger side fender well and put in a K&N filter
3--Get a larger MAF sensor
4--bump your timing up a couple of degrees
5--complete tune up if it's been a while or you're unsure....wires, plugs, cap, rotor, fuel/oil filter, oil change
gspfunk is offline
Old 05-10-2006, 02:24 AM
ikeybmg
ikeybmg's Avatar
you need a better flowing exhaust, like flowmasters or magnaflow, slp or mac, etc. you have emissions test where you are? if not, a hi flo H pipe would be a good invesyment too. 3:55 or 3:73 gears would give it a torquey feel. those 2 things would make you think you had a different car and would sound alot better too bro. than a cold air intake with a bigger throttle bod and mass air meter would be next for me. removing the air silencer too like the guy above said and putting a cold air in would help it breath better, meaning +hp and better gas mileage. the air silencer is that big plastic box that takes up all that space under your hood and what covers up your air filter and such.
ikeybmg is offline
Old 05-10-2006, 02:30 AM
BurninOne
BurninOne's Avatar
thanks for the help, I dont know much about mustangs this help alot I'll get to work on the things yall said, once again thanks
Old 05-10-2006, 02:37 AM
ikeybmg
ikeybmg's Avatar
youre looking at about 400-600 gor the rearend gears and install, 325 for the flowmasters, 200+ for the hi flo catted H pipe, 2something for the throttle body, 2something for mass air, 100 for the cold air intake. so youll need to take it step by step. but do the gears and exhaust first.
ORIGINAL: BurninOne
ikeybmg is offline
Old 05-10-2006, 02:54 AM
BurninOne
BurninOne's Avatar
Yea thats what my brother told me to do first was gears and exhaust, and then when yall told me that I knew to go ahead and start lookin into it so thanks for the help and I know it aint going to be cheap, so its going to get done very slowly
ORIGINAL: ikeybmg
ORIGINAL: BurninOne
Old 05-10-2006, 02:58 AM
93BlackNotch
93BlackNotch's Avatar
Their is really no point in buying a MAF unless you need it for bigger injectors... Believe it or not, stock intake, throttle bodies, and alot of other things are good up to 400RWHP....
93BlackNotch is offline
Old 05-10-2006, 03:01 AM
ikeybmg
ikeybmg's Avatar
i call bs on that. a 65mm tb and 70-75mm maf calibrated for stock injectors and with a cold air intake will make hp. prolly 10-15 over stock.
ORIGINAL: 93BlackNotch
ikeybmg is offline
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
RCS02v6
09-29-2015 01:46 PM
junior04
09-28-2015 10:53 AM
GLOCKer
09-28-2015 07:36 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: I need some info!!
