H.P. and 1/4 times
H.P. and 1/4 times
so i just got done putting together my little combo and was curious what u guys thought about it (ex: power, somthing doesn't quite match with others..) i haven't put it in the car yet and just wanted to know what you guys tought. here's what i have; 306 w/ an F303 cam (.512" & .512"), 1.6 roller rockers, Trick Flow Track Heat intake, ported stock heads, 24 lb injectors, 255 lph fuel pump, 75mm throttle body (overkill?), 77mm MAF, 1 5/8" primary to a 2 1/2" coll. long tubes, matching pro chamber followed by a set of 40 series, under drives, a/c eliminator, smog delete, E-fan, all in front of a rebuilt AOD w/ a shift kit and a 2300-2500 stall and a set of 3.73's. what kinda realistic times do you think i could expect?
mungodrums
10-07-2015 04:01 AM
09-08-2015 11:50 AM
