inside light
#23
RE: inside light
thts it bro.
ORIGINAL: mustang_cab
the thing that sticks out of the door pops out when you open the door on both sides of the car. it feels like it has a spring that pushes it out when u open the door. thats the only thing i found. is that the right one?
#25
RE: inside light
where are the othe fuses other then the ones under the hood?
#28
RE: inside light
the underhood switches are prolly the ones you should check. all the small ones anyways. the big ones under there wont be worth checking because it wont be them.
all fuse look good. should i check the ones under the hood. just for the hell of it?if its not the fuses it has to be the switchs are bad right?
