beeping noise
RE: beeping noise
ORIGINAL: Tims 88GT
i dunno, but when i had my dash out and a whole bunch of stuff unpluged it beeped, i had the steering wheel off to. 92 has air bags.
RE: beeping noise
no[&o]
ORIGINAL: PRO50SC
Really, are you sure about that?
ORIGINAL: Tims 88GT
RE: beeping noise
ORIGINAL: Tims 88GT
someone is trying to hijack your P-51 Mustang
ORIGINAL: AdderMk2
OMG... YOUR FLIGHT RECORDER IS BEEPING!!!!!!!!!
ORIGINAL: ikeybmg
i agree, black box thingy [&:]
RE: beeping noise
Prove Out System
"PROVE OUT SYSTEM" means to turn the ignition switch (11572) from OFF to RUN and visually monitor the air bag indicator with the air bags installed. The air bag indicator will light continuously for approximately six seconds and then turn off. If an air bag system fault is present, the air bag indicator will either:
Fail to light
Remain lit continuously or
Flash.
The flashing may not occur until approximately 30 seconds after the ignition switch has been turned from OFF to RUN. This is the time required for the air bag diagnostic monitor to complete testing of the air bag system. If the air bag indicator is inoperative and an air bag system fault exists, a tone will sound in a pattern of five sets of five beeps. If this occurs, the air bag indicator will need to be serviced before diagnosis can be continued.
Components Location:
Air Bag Diagnostic Monitor and Bracket -- In center console behind climate controls.
Fail to light
Flash.
Hope this helps.
