5 lug swap kit?
5 lug swap kit?
ok i want to do a 5 lug swap and 50resto has a pretty good deal on the kit its like 400 bucks for everything. looks pretty good what ya think?
http://www.latemodelrestoration.com/...0%201&comp=LRS
RE: 5 lug swap kit?
You will only be able to run certain wheels w/ that set up. You should do the sn95 conversion.
https://mustangforums.com/m_968156/tm.htm
RE: 5 lug swap kit?
I steer away from those kits only because the back brakes remain as drums. If your gonna do that go all the way and do a kit that will convert it to 4 wheel disc.
Steeda makes one. A little pricey but stopping is always a good thing.
[IMG][/IMG]
Cobra "R"
Disc Brake
Conversion
Cobra "R" Disc Brake Conversion
$2100.00
You've invested into your Mustangs power and handling. The next and most important upgrade you need is brakes. This is the most comprehensive, performance braking system available for the 1979-1993 Mustang. Steeda's Cobra "R" 4-wheel conversion kit includes everything required to convert your stock brakes into a professional, race-ready system. Large 13" vented front rotors and 11.65" vented rear rotors make this the ultimate brake kit for your fox body Mustang. Steeda's complete kit includes all new rotors, master cylinder, proportioning valves, lines, brackets, hardware... everything.
NOTE: Requires 17" 5 lug wheels.
*Installations on 1979-1986 requires upgrading to 1987-1993 front struts.
© 2002 STEEDA AUTOSPORTS INC. All Rights Reserved. 1351 NW Steeda Way Pompano Beach, Florida 33069
[IMG][/IMG]
Cobra "R"
Disc Brake
Conversion
$2100.00
RE: 5 lug swap kit?
^^^^^^^^^thats a nice kit^^^^^^^^^^^^^^
Im not sure what year your car is or if your kit comes with front spindals and calipers like the kit above. Pre-1987 fox mustang will need 1987-(1995or so) front spindals and calipers. I just looked at the kit you had in mind and it said 87-95. it can also be used on fox cars before that as long as the spindals and calipers are changed to 87-95. My car is 1983 and has a 5 lug conversion. I went to a junk yard for the spindals. The calipers and pads you just buy new.
RE: 5 lug swap kit?
Easiest and cheapest way to do the 5 lug swap, youll need 87 up spindles, front rotors calipers from a lincoln mark 7, and for the rear youll need the axles and all of the brake stuff i.e. backing plates cals, rotors. I cant remember (been a while since i did one) Im pretty sure the axles are the right length, Im not for certain though. Another method for rear disk is getting a setup off of an explorer w/ an 8.8, the axles wont work out of the explorer but everything else will.
-P.
-P.
RE: 5 lug swap kit?
These guys have nice kits too.
Saw their parts used on HPtv this weekend. you can piece together
a pretty good kit and not spend a fortune
They have kit similar to Cobra conversion with smaller disc for lot less $$
http://www.stainlesssteelbrakes.com
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
09-16-2015 07:53 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-01-2015 08:16 PM
