injecter cleaning
RE: injecter cleaning
its all bad on your plugs. thats why i try to up-sell pcv/spark plug/wire tune ups. that fuel systems cleaner is some nasty ****. one of the guys at work spilt some on his arm and it burned him up pretty good.
ORIGINAL: Tims 88GT
injector cleaner is hard on ur plugs, u need to go some place that does a fuel system clean and have that done.
our fuel system service consists of throttle body cleaning, fuel tank additive, fuel injector cleaner ran through the rail, and upper intake cleaner ran through upper vacuum line ~~~ $150 parts and labor
if u run cleaner through your tank it loosens up all the sediments throughout the entire system and tries to run it through all the components. and things such as the injectors that you are trying to clean MAY become clogged with the things that are in the tank and or lines. so at least keep that in mind with whatever your decision is
ORIGINAL: greenstreak9205
jwog666
12-27-2021 08:09 PM
