smog pump elim.
RE: smog pump elim.
me and my dad have a rule i dont mess with the motor since i know jack so i have to wait till this weekend unless somebody can tell me the belt size before hand, cuz hes installing my udp's this weekend and fixing a few other things.
RE: smog pump elim.
If I understood correctly, you're trying to do something like I did to my car in the pic below?
That was something like a 92" belt
[IMG]local://upfiles/16761/62FF1623DAD74F3C93CA68FE7B89B9BF.jpg[/IMG]
RE: smog pump elim.
I tried that but for some reason it wouldn't work. I had issues with the belt wanting to rub it's self at the water pump and idler. I went tight as i could and be able to get it on. Even took the idler loose so I could get it up higher to fit a smaller belt. Then the idler had enough force it pushed it down close to the water pump. I thought it would be fine but drove a couple blocks and checked it, the belt was almost rubbing it's self so I said SCREW IT and took the belt back and got the stock one using the smog pump. Have to buy the delete I guess?
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
