Help with a/c delete install
I just got my a/c delete from ford racing and It came with no directions. As far as I know the power steering pump is moved to where the a/c was right? Well I have the two brackets that came with the kit and Im not sure how it all works.
RE: Help with a/c delete install
OK I just took that off my car and I can kinda recall from memory. You should have an aluminum piece and a larger black steel piece. The aluminum piece bolts to the end of the head (flat side towards the head obviously) and the steel piece bolts up against several of the water pump studs. You will see a round indentation in the steel piece. This is to adapt to the varying depth of the couple water pump bosses that it bolts up against. When you are done you should have one of the pieces on the front of the pump and one on the back.
I hope that helps you some.
Mark
Mark
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
86, 87, 95, ac, delete, ffrp, ford, gt, install, installation, installing, instructions, instrustion, kit, motorsports, mustang, racing
