fuel injectors question.
ok heres what im basically gonna be doing, headers, the trickflow kit, 70mm tb 73mm maf sensor maybe 76. which injectors should i use 19# or 24# would it run bad if i stayed with my 19#?
RE: fuel injectors question.
19's will be fine. just get an adjust f/p/r. and turn up the juice a little
24#. its not that it will run bad. 19# are good up to 300hp but you want it to run right, dont you?
its not good above 300 hp?
