302 Boyz
302 Boyz
I dropped a 302 in my 68
I have not hooke dup the EFI and m running an Edelbrock 600
Edelbrock Heads
Stock Cam
I am having some issues with the timing and power band, it just seems to lack guts at this point. Any thoughts?
T
Edelbrock Heads
Stock Cam
T
RE: 302 Boyz
ORIGINAL: Hurricanedt77
10 Avanced is baseline from the facotory at idle
Mark
RE: 302 Boyz
On my '85 (carbed) its set to 13 BTDC. Also, what timing gears are you using? I once bought a set the had 3 different ways you could mount it, this was on my first stang (79)when I was 17 or so, anyway I accidentally put it on one of the other holes, and the car made NO power at all with the factory timing. I actually had to retard the timing like crazy, it was set @ 5degrees ATDC. It ran like a raped ape after that.
-P.
PS: I usually NEVER use a timing light to time cars, I do it by throttle response. Basically, rev the motor, when theres NO hesitation your timings dead nuts.
-P.
