whats better
whats better
what is better, i own a 95 mustang cobra SVT and it has the 302 in it. proople have been telling me that i should put a 347 stroker in it, but i wana put a supercharger on it. and what i wana do is make it a 351. what is better. here is the suppercharger that im going to put on it.
http://www.kennebell.net/supercharge...-flowzilla.htm
RE: whats better
you sure?? i think it is possible to bore it out that much, but it wont run for long. the cylinder walls have to be thicker or they will melt from the heat. even if there is a kit, i can guarentee its not safe, especially if youre going to boost it.
RE: whats better
351 from a 302? lemme see it! pics. info anything. ill have to be made a believer on that one.
ORIGINAL: alden918 95 svt
na there is a kit for the 351 and i own it but i wana make the right choice
RE: whats better
If you're wanting power out of it, go w/ a 351 block. The stock 302 block is only good to between 450-500 hp, depending on tune and such.
I'm guessing the 302-->351 stroker you're talking about is .040 over? I don't think you can safely bore them over more than that.....
