Overheating????
05-21-2006, 04:10 PM
RE: Overheating????
75ft lbs
05-21-2006, 04:11 PM
RE: Overheating????
i've seen this problem on other forums, and new head bolts fixed the problem
the stock bolts are one time use only
05-21-2006, 04:13 PM
RE: Overheating????
I am almost sure that is you problem....whenver you change heads, bolts are a must.
05-21-2006, 04:14 PM
RE: Overheating????
so rip it back apart and put new gaskets and new bolts in
05-21-2006, 04:23 PM
RE: Overheating????
well one thing to check is...if the bolts are at fault...are they weeping?....if so that where most of your air is coming from
05-21-2006, 04:26 PM
RE: Overheating????
what u mean internal or external
RE: Overheating????
Quote:
ORIGINAL: 86_GT_5.0
Or...you may want to do a combustion leak test with one of
these to confirm it's a head gasket problem. My
05-21-2006, 04:30 PM
RE: Overheating????
+1 on that
05-21-2006, 09:21 PM
RE: Overheating????
If you do replace your bolts, go w/ ARP head studs. They are reusible b/c they tq down on the head itself, not the stud/shaft of the bolt. Best $75 I ever spent on ebay.
05-21-2006, 09:45 PM
RE: Overheating????
+1^^ Regular bolt set will cost you at least 50 bucks each time...I like the stud idea also.
BOB ROME
07-26-2023 01:54 PM
mungodrums
09-29-2015 09:18 PM
yourmom6990
09-14-2015 10:52 PM
MusicCity615
09-12-2015 07:05 AM
96stang3.8
09-10-2015 06:42 AM
