Is it posible
Is it posible
Someone i know told me that its ok to put gt40 heads and a E303 cam on stock motor with out having to change the intake or anything else. Is this true and also can you still use it as a daily driver.
RE: Is it posible
86 is CFI, 87-88 are speed density. An E303 is too much for gt40s anyway. A B303 would be better suited for that getup. Or you could just take out the FI all together and use a carb. The intake is A LOT cheaper around 250, and you can pick up a good 650 CFM carb for about 300. You can retain your stock disty as the ignition module is mounted right to it. The only other thing youd need is a throttle cable off of an 85GT.
-P.
PS: I hate FI for non turbo applications.
-P.
RE: Is it posible
ORIGINAL: P Zero
-P.
-P.
RE: Is it posible
ORIGINAL: P Zero
-P.
-P.
thatscrazy00
10-18-2007 01:59 PM
TeflonDon
08-15-2006 01:12 AM
