Trans Mount Replacement Help!
I was replacing my trans mount and crossmember bushings. Pretty simple, I put my crossmember back in and now the mount won't line up with the crossmember. My trans needs to move about an 1 1/2 inches towards the passenger side. I've tried both mounts and the trans is just way off. I've tried flipping the crossmember around and the bolt holes for the mount line up buy the crossmember hits the pan. I have also loosened the motor mounts in attempt to move the trans over but no luck. Any help would be great, I have to get my car back together
RE: Trans Mount Replacement Help!
ORIGINAL: 82FBGT50
YOU HAVE THE CROSSMEMBER UPSIDE DOWNN!!! just flip it around and it should work
Thanks for the help guys.
09-01-2015 08:16 PM
