Stock Operating temp?
In approximately 65 degrees what is the normal operation temp. It appears my radiator is clogged because when I went to do a flush it only dribbled out of the plug on the lower right and after I dumped the lowest hose It refilled a lot less than it should of. Mine is running two and a half points above the lowest point on the temp gage.
RE: Stock Operating temp?
WEll you didnt really flush it. After you disconnect the lower hose and most of the fluid drains out, remove the upper hose from the thermostat housing and with a slow but steady stream flush out the motor.
-P.
-P.
I flused a hose through the radiator. Should the radiator drain lots through the lower right drain plug?? I remembered when I went to refill the radiator it should of gulped up more coolent.
TfcCDR
09-14-2015 12:08 PM
