Hyper Pistons
Hyper Pistons
OK. Lets talk Hyper pistons. Are they really THAT bad to use. I am looking to buy a 93 that obviously has hyper pistons in it... would I be OK with your average bolt ons (h/c/i) and a small shot (75-100 shot)? What about boost? Are they safe? Thanks guys.
RE: Hyper Pistons
ORIGINAL: 88BlueGT
RE: Hyper Pistons
ORIGINAL: 88BlueGT
So basically I could run just as big of a shot on a hyper piston as a forged piston. Also, I should be OK w/ boost too? Any limits?
RE: Hyper Pistons
manufacturers switched to the hypereutectic pistons because they are harder (but not stronger), so they can be used with smaller clearances than forged pistons, which in turn allows for less blow-by and other similar stuff, which in turns eliminates some pollutants (that is probably the biggest reason for the switch) and power loss. they also claim that you can run the newer hypereutectic pistons for more mileage with all else equal.
Another thing I've seen is that the hyper internals are more likely than forged internals to send pieces through your cylinder walls during detonation or other such disasters. I think this is the main reason the manufacturers use forged instead of hyper internals for factory boosted applications, not neccessarily for strength only.
RE: Hyper Pistons
So bottom line, I will be OK w/ a small shot and the normal bolt ons (h/c/i). So will they be able to hold up against 400hp? I am using 400 as a number considering a nice h/c/i will put you in the 3's plus a 75-100 shot.
