turn signal switch
turn signal switch
What could cause the turn signals to not work?
Every once & a while the headlights will turn off, i have to wiggle the switch to make them come back on. I've tried replacing the switch with the one out of my friends 87 GT, no luck. All the fuses are good. I've replaced the flasher under the fuse box. I've heard there is another flasher near the glovebox.
RE: turn signal switch
When your headlights flicker, are your fogs on? Mine used to do that. I turned off the fogs and they stopped going out. If you need a new switch, they're like 30 bucks at Advance or Autozone.
As far as turn signals, you might need a new multi-function switch, which is the one on the column.
Check www.50resto.com for a new switch unit. My headlights shut off too and I fear that this might happen to mine eventually. You can get the kit there for the headlight and multifunction switch for $200.
ORIGINAL: FordMustangXBA
Could this be the hazard switch? Before I had tried using my turn signals only to find that my hazard light switch was on. It's off now, but could it be a possibility?
ORIGINAL: FoxGT
Yes, the fog lights are on when they do it. I think i've tried turning them off when the lights went out, They stayed out... My running lights stay on, but the headlights went out. The one I replaced was the one on the steering column. I figured it was the switch causing it, but apparently not.
Ah... Not the switch, it's the wire going to the switch... Aparently that is the cause of my turn signal switch going out. & it appears to be a problem on all the foxes. Thanks for tip
TfcCDR
09-14-2015 12:08 PM
1989, 86mustang, 89, blinker, flicker, forums, gt, headlights, lights, mustang, signals, switch, turn, turnsignal, turnsignalflasher
