Injectors/AC
Injectors/AC
I need to change my stock injectors, the car has a blower and cam. What size should I get? Also what would be involved in bigger sized injectors. I also want to remove my A/C, could I just disconnect it and get a shorter belt or would i need to get a pulley to takes its place? Thanks for all the help
RE: Injectors/AC
my 89 5.0 w/ 8 lb powerdyne stock cam has only 24 lb injectors... If you're doing only around 5-6 lbs, I would recommend 24 lb injectors... If you're going from 7-10 lbs, I would recommend a set of 36 lb... You'll really need an adjustable fpr to make this work right, but going a little bit bigger than what you ened is a good thing. That way when you bolt on a big set of heads, or turn up the boost with some pulleys, you're fuel willl be waiting to match it.
