can someone calculate my compression..
RE: can someone calculate my compression..
So if that is the case, what is the PSI threshold to tell if you have problems within your engine or not?
ORIGINAL: tinman
No, that is useful for trying to figure out damage to engine.
there no way in H that will figure compression ratio now or ever......
you guys seem to be talking on 2 different planes. The guy wants to know compression ratio ie; 9:1-10.5:1 NOT cyclinder compression 150psi-160psi. To accurately calculate his compression ratio he needs to know a bunch of things. chamber volume,head gasket compressed thickness, gasket bore size, cc's of relief valve on piston, how far piston is below the deck. Give me those and I can tell you CR
were seeing I 2 I myshifter. i figured it close to around 11.3.1. i have 60cc combustion chamber, .040 head gaskets, flat top pistons, 4.030 bore, 3.40 stroke, which is as, yall know, a 347. only thing im not sure about is the deck height.
ORIGINAL: ikeybmg
yesser they do. id say youre pretty accurate. so its bound to fall somewhere in between mine and your calculation then, though prolly closer to yours thanks man.
ORIGINAL: myshifter
10.9 ASSUMING a few things, piston is 10 thou below deck, maybe-maybe not. Gasket bore is 4.040(probably) 1-2 cc relief on piston ( they have a valve relief right?)
