can someone calculate my compression..
or show ma a decent link to a calculator. i have a 347, vic jr heads, 2.05 1.60 valves, 210cc, 70cc combustion chamber. ross forged flat tops. anything else im leaving out that ill need to know? thanks guys.
RE: can someone calculate my compression..
lets get technical.............
compression ratio is the ratio between the volume of
the cylinder and combustion chamber when the piston
is at BDC vs. that same volume at TDC.
You need the following engine information
C ..... Combustion chamber volume
G ..... Compressed head gasket volume
D ..... Piston/Deck height
P ..... Piston dish volume
V ..... Cylinder volume
so your compression ratio is ratio between
V+D+G+C+P : D+G+C+P
btw: got all that out of following book, very good reading
http://www.amazon.com/gp/product/193...v=glance&n=130
V+D+G+C+P : D+G+C+P
ORIGINAL: tinman
No, that is useful for trying to figure out damage to engine.
there no way in H that will figure compression ratio now or ever......
