Oil drain plug washer?
RE: Oil drain plug washer?
actually, at work, when the drain plug is leaking we just replace the whole plug/washer assembly. i also like to put the magnetic plugs in too. so when the next oil change comes around you can get a heads up to any internal problems.
but those nylon washers are pretty durable.
The nylon one will work. I have one on both off my drain plugs. It crushing itself when you tighten down the plug and seals it. My doesn't leak from the drain plugs at all. I've reused my plastic one no problems also.
ORIGINAL: Twisted
Thanks for the replies folks. I'm just glad someone has seen plastic ones before. Did your plastic washers come from the dealer? I guess I'll check with another dealer, and see what their washers are made of. It sucks though because I just changed my oil. On another note, it could be leaking because I'm a girl about tightening bolts, after having stripped so many in the past. Thanks again.
ORIGINAL: 1990mustanggt
I don't know about nylon, but all the ones I use are plastic
One thing you can try gr84u is to put some grease on your wheel studs. The lugs will not rust to them and they go on and off a lot easier. Its just a good trick thats nice to know.
ORIGINAL: gr84u
I feel you man, ever since my brother shattered a lug-wrench engd in on one of my lugs in my wheels (taking one month to get it out), I am a little more careful about who I hand tools to and how much power I give everything.
ORIGINAL: Twisted
ORIGINAL: 1fastzook
i got some metal and rubber oil plug washers from the local percision tune they worked pretty good.
stangin1996gt
09-21-2015 11:01 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
