Oil drain plug washer? - MustangForums.com
Old 05-30-2006, 07:04 PM
Twisted
Default Oil drain plug washer?
So I went to Ford to get oil drain plug washers for my 88. They told me that the washers were not sold seperately, and that I'd have to buy the whole plugs. So I did. I noticed, however, that the washers are nylon. Since changing the plugs, I haven't been able to get my rear oil drain plug to stop leaking. Are these washers supposed to be nylon?
Twisted is offline
Old 05-30-2006, 07:42 PM
Twisted
Default RE: Oil drain plug washer?
Surely someone's changed their oil before.
Twisted is offline
Old 05-30-2006, 07:44 PM
1990mustanggt
I don't know about nylon, but all the ones I use are plastic
1990mustanggt is offline
Old 05-30-2006, 07:45 PM
Mustangn
The orignal one are metal with ruber on the inside, and I have bought them separately from ford dealer here.
Mustangn is offline
Old 05-30-2006, 07:52 PM
92hatchLX
I think that my washers are all metal. Take them back and tell them that they are leaking.
92hatchLX is offline
Old 05-30-2006, 08:00 PM
Twisted
ORIGINAL: 1990mustanggt
Thanks for the replies folks. I'm just glad someone has seen plastic ones before. Did your plastic washers come from the dealer? I guess I'll check with another dealer, and see what their washers are made of. It sucks though because I just changed my oil. On another note, it could be leaking because I'm a girl about tightening bolts, after having stripped so many in the past. Thanks again.
Twisted is offline
Old 05-30-2006, 08:17 PM
Boss_Hotrod
I bought a metal one with a rubber insert from advance a couple months ago. Hasnt leaked yet.
Boss_Hotrod is offline
Old 05-30-2006, 08:40 PM
FiveLiterRiceEater
thats probably why its leaking..man up and tighten the plug like you got a pair *****
just kidding but i've never had a nylon washer leak on me. just try to tighten it up a little more. if it still leaks tell ford they're idiots cause they gave you ****ty washers.
FiveLiterRiceEater is offline
Old 05-30-2006, 08:57 PM
Grimace5.0
I ♥ Acer
AutoZone has a assortment pack. They also have "behind the counter" composite washers. If the nylon is too hard of a material you may want to try one thats made of softer material.
Grimace5.0 is offline
Old 05-30-2006, 09:18 PM
Twisted
ORIGINAL: FiveLiterRiceEater
LOL. Duly noted, Fiveliter. I just tightened it today--snugged it up pretty good. I hope it won't leak now. I just thought it was strange that A) The dealership gave me plastic washers, and B) They didn't sell such a flimsy (plastic) washer seperately (without the entire plug), as it seems like you'd have to replace it often. Do these plastic ones last a while?
Thanks for the replies, Grim and Boss. I'll try a different kind if these plastic jobs don't hold up.
Twisted is offline
Quick Reply: Oil drain plug washer?
Featured Sponsors
