Can someone get me a pic of,....
This please? It is the vacume lines on the RR of the motor. Mine were real brittle and broke off during the latest round of upgrades. Headers, losing the smog stuff, pullys, etc,..
Since I don't have the smog stuff, I can cap off 2 of those lines, but I don't know which ones, and where the others go.
Any help is appreciated am getting closer to finishing the project.
Thanks!
Darrin
[IMG]local://upfiles/26697/7AD5F66AB5CA497ABBB9CA200CDA1995.jpg[/IMG]
Thanks!
Darrin
RE: Can someone get me a pic of,....
Anyone?,..Please, I am close to getting the car ready to drive, and the location of the vacume lines are all that I will need by tonight.
Thanks,
Darrin
Thanks,
Darrin
I dont know how they go but just try and plu all of them into and see what happens. Ours only have two hoses comming out of it and if it falls off we just stick it on theyre. We dont have any problems. Not sure if the car has been chipped or not.
here's a picture and description from a past post. i haven't taken a picture of the vac lines on my car but here's a pic of RumbleBee89gt's vac plug and my description of where they go.
http://i13.photobucket.com/albums/a2...aintake003.jpg
Described as looking at the picture......
Top right - Goes to Air Bypass Valve which is located directly behind the smog pump
Top left - Goes to EGR valve
Middle - Goes to Air Diverter Valve located downstream from Air Bypass Valve
Bottom left - Goes to back of upper intake, driver side nipple(there are 2 side by side, the one on the passenger side goes directly to the FPR)
Bottom right - not used, should have no line on either side of vaccuum plug.
whats that blue tubing?
i broke the air check valve on mine. its the little brass (its not made of brass) thing that looks like a bell. it connects to the blue tubing in that picture.
Thanks Guys!
5.0Trippin that is just what I needed, It is amazing how much better it runs when the lines are all hooked up correctly!
Now I gotta plumb in the electric fan, and a few other od's n end's and It should be back on the road by tomorrow.
Thanks again,
Darrin
Thanks again,
Darrin
