HELP...what belt do I use???
Can anyone tell me what belt I need to use on my 92 302. I have no smog pump and no pulley in place of it. I recently took off the A/C and got a Ford Racing A/C eleminator kit. The kit moves the power steering pump up. I need to know what belt to use or what I can do to figure it out.
RE: HELP...what belt do I use???
two ideas. one call the Ford Tech line at 586-468-1356
second get a thin metal tape measure, like 12 ft length and run it around the pulleys in the exact path that the belt needs to run it and get the measurement in inches from the tape. take this to the auto parts store and see if they can't match it up or get pretty close and try the belt they give you and see how it works. if too loose, get one a couple inches shorter, too tight, get one longer until you hit the right size.
autoedit
09-27-2015 06:37 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
