running rich
RE: running rich
Fuel pressure too high
Bad FPR. allowing fuel to get through the vacuum line
Bad PCV
Coolant Sensor (ECT)
Air Charge sensor (ACT/IAT)
O2 Sensors
Faulty/contaminated MAF
Engine oil contaminated (fumes recirculated through PCV system)
ECM
Bad grounds
EGR valve
Low timing setting
Canister Purge solenoid (CANP)
Injectors
Suggest to run a set of DIY KOEO/KOER self-test and a fuel pressure check to start removing possible causes from the list....My 2¢.
Bad PCV
O2 Sensors
ECM
Bad grounds
EGR valve
Low timing setting
Injectors
