fuel pump Q
RE: fuel pump Q
Lil advice, make sure the tank is empty and those clips on the fuel lines going into the tank be very careful with them all you have to do is pop the clip off and then the lines come free. Remember to use a brass chisle when hammering the pump hold down ring off then its like 1.2.3 its about a 6 out of 10 on the hard scalke
RE: fuel pump Q
ORIGINAL: schwindty
I used a block of wood. Also get yourself a can of electrical cleaner and dielectric grease. Clean all the connectors and grease them back up. Be careful when your taking the filler tube out of the tank, if you tear the gasket you have to order a new one cause its not sold locally. Might want to use some WD 40. While your down there change your filter. Prime it real good when your finished. You might need to jack your tail end up to get the tank out, it makes it a little easier.
mrappe
09-26-2015 10:16 AM
