My Vacume reading good or bad?
Hi, i just got done installing my vacume gauge and this is what i found on idle.. 11 psi of vacume. I dunno if that is good or bad, keep in mind that i do have a big cam (.565 lift and .565 lift custom grind) Thanks in advance for the replies.
RE: My Vacume reading good or bad?
Camshaft Specification Table
Part Number 35-518-8
Engine 1969-1995 Ford
351ci,
Windsor,
8cyl.
Grind Number FW XE274HR-12
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.555 0.565
Duration At 0.006 Tappet Lift 274 282
Valve Timing At 0.006
Open Close
Intake 29 65
Exhaust 77 25
These Specs Are For The Cam Installed At 108 Intake CL
Intake Exhaust
Duration At 0.05 224 232
Lobe Lift 0.348 0.354
Lobe Separation 112
Recommended Valve Springs 986-16
351ci,
Windsor,
8cyl.
Description
Intake Exhaust
Open Close
Intake 29 65
Exhaust 77 25
Intake Exhaust
Lobe Separation 112
or go here if that is confusing
http://www.compcams.com/Technical/Se...umber=35-518-8
274°/282°, 224°/232° @.05", 112 LSA and 54° Adv. OVL, +4° OVL @.05" making 11"Hg @idle...a little lope idling?........@1,100 rpm it should jump to 18"-22"....right?
Diode Dynamics
28
05-26-2022 12:02 PM
Faolan65
Arizona Regional Chapter
08-25-2015 09:24 AM
