Diesel?Weird? Maybe. Yes, weird
Old 06-02-2006, 10:07 PM
HACKGT350
HACKGT350's Avatar
Default RE: Diesel?Weird? Maybe. Yes, weird
get a can or carb cleaner or wd-40 and start spraying the hoses when you it the leak youll know
HACKGT350 is offline
Old 06-02-2006, 10:10 PM
93BlackNotch
93BlackNotch's Avatar
If it's an Auto shut the car off in Drive... If not just release the clutch a bit while it's in 1st gear, shut the key off, and it will stop doing it...
93BlackNotch is offline
Old 06-02-2006, 10:22 PM
ZachW04Stang
ZachW04Stang's Avatar
It shouldn't be doing that if its fuel injected. Once the key is off there shouldn't be any spark or fuel being put into the engine. On carb cars when timing is too high it will do it.
ZachW04Stang is offline
Old 06-02-2006, 10:36 PM
JBradley500
JBradley500's Avatar
you time it? if you time it with the vaccum advance hooked up it makes the timing off enough to do that.
JBradley500 is offline
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Generally the idle being too high causes this. What's yours set at?
PRO50SC is offline
Old 06-03-2006, 12:39 AM
knucklefux
knucklefux's Avatar
i'll tell you something else that will cause it. if you have an aftermarket ignition, say msd for instance, and the wire that comes from the ignition that turns the ignition on is connected to the wrong thing, it will pick up enough electricity from the alternator continuing to turn to keep the engine running. that's why msd has that little wiring diagram with the diode in the circuit...msd calls it run on.
knucklefux is offline
AmericanMuscle4.6GT
11-10-2015 02:06 PM
mungodrums
09-28-2015 10:54 PM
2015Ecoboost
09-17-2015 01:48 PM
MasterLanMan
09-13-2015 08:21 PM
Quick Reply: Diesel?Weird? Maybe. Yes, weird
