What the hell is going on with my car?
Today i opened my radiator cap and the fluid was solid looking, like it froze. And then i had to go to work but my step dad worked on it and he said the fluid was really really really cloudy, but they checked my oil and i didnt have a drop of it in my car. Thank god i didnt drive it any more, but yeah. We put stop leak in my radiator since it was leaking and it did stop leaking but then it started to this morning. Could that be because of my oil? or what? its really confusing and we are all confused about what it could be. Why would where the antifreeze goes freeze?
RE: What the hell is going on with my car?
If it looked like mud it could look like that because someone mixed regular and dexcool together. Believe it or not it makes the coolant look like mud. It could just be no one ever changed the coolant. Pressure test the system and find out where the leak is coming from.
ORIGINAL: ZachW04Stang
Replace the radiator if thats where the leaks coming from, do be afraid to remove the fan shroud first then pressure test just to make sure. That little extra work might save you some money. Have a shop use a coolant flush machine (about $50-$70) on your car one you've fixed the leak. It will get a lot of crap out of your system.
ORIGINAL: Black95MustangGT
yes i checked my oil a couple weeks ago and it was somewhat low so i put more in and it was fine.
a blown headgasket, we put stop leak in it and it was bashe, im told by some people on here thats what could make it bashe. It was really really light like a tan, and really liquidy if that helps.
